The 19" regular LED monitor VB199T adopts advanced mercury-free and wide viewing angle LED-backlit panel to deliver many benefits of better visual details with high contrast ratio, energy saving with lower power consumption, and reduction of environmental pollution.
Product Description | ASUS VB199T - LED monitor - 19" | Device Type | LED-backlit LCD monitor - 19" | Power Consumption (On mode) | 18.4 W | Panel Type | IPS | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 | Pixel Pitch | 0.294 mm | Brightness | 250 cd/m² | Contrast Ratio | 50000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC | Input Connectors | DVI-D, VGA | Speakers | Integrated | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 41.3 cm x 21 cm x 41 cm | Weight | 3.2 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, TUV Ergo, PSB, FCC, RoHS, ISO 9241-307, WEEE, J-MOSS | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 19" |
Panel Type | IPS |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 53 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Controls & Adjustments | Volume, brightness, colour temperature |
Features | sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 72% NTSC colour gamut |
Colour | Black |
Dimensions (WxDxH) | 41.3 cm x 21 cm x 41 cm - with stand |
Weight | 3.2 kg |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 1 Watt |
Connectivity | |
Interfaces | DVI-D , VGA , Audio line-in |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x audio cable , 1 x DVI cable |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 17.1 Watt |
Power Consumption Stand by | 0.37 Watt |
Power Consumption Sleep | 0.35 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 41.3 cm - depth: 6.48 cm - height: 34.24 cm , With stand - width: 41.3 cm - depth: 21 cm - height: 41 cm - weight: 3.2 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - LCD panel - 3 years |
