The 19" regular LED monitor VB199TL adopts advanced mercury-free and wide viewing angle LED-backlit panel to deliver many benefits of better visual details with high contrast ratio, energy saving with lower power consumption, and reduction of environmental pollution. VB199TL comes with an ergonomic design of height, tilt, swivel, and pivot adjustment for personal visual comfort.
Product Description | ASUS VB199TL - LED monitor - 19" | Device Type | LED-backlit LCD monitor - 19" | Power Consumption (On mode) | 18.4 W | Panel Type | IPS | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 | Pixel Pitch | 0.294 mm | Brightness | 250 cd/m² | Contrast Ratio | 50000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC | Input Connectors | DVI-D, VGA | Speakers | Integrated | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 41.3 cm x 21.4 cm x 46.6 cm | Weight | 4.7 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, TUV Ergo, PSB, FCC, RoHS, ISO 9241-307, WEEE, J-MOSS | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 19" |
Panel Type | IPS |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 53 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Controls & Adjustments | Volume, brightness, colour temperature |
Features | sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, integrated cable management, 72% NTSC colour gamut |
Colour | Black |
Dimensions (WxDxH) | 41.3 cm x 21.4 cm x 46.6 cm - with stand |
Weight | 4.7 kg |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 1 Watt |
Connectivity | |
Interfaces | DVI-D , VGA , Audio line-in |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 100 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x audio cable , 1 x DVI cable |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 17.1 Watt |
Power Consumption Stand by | 0.37 Watt |
Power Consumption Sleep | 0.35 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 41.3 cm - depth: 6.48 cm - height: 34.24 cm , With stand - width: 41.3 cm - depth: 21.4 cm - height: 46.6 cm - weight: 4.7 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - LCD panel - 3 years |
