Marketing description is not available.
Product Description | Crucial - DDR4 - kit - 128 GB: 2 x 64 GB - LRDIMM 288-pin - 2400 MHz / PC4-19200 - LRDIMM | Product Type | Memory kit | Capacity | 128 GB: 2 x 64 GB | Memory Type | DDR4 SDRAM - LRDIMM 288-pin | Upgrade Type | Generic | Data Integrity Check | ECC | Speed | 2400 MHz (PC4-19200) | Latency Timings | CL17 | Features | Quad rank, Load-Reduced | Voltage | 1.2 V | Manufacturer Warranty | Limited lifetime warranty (Germany - 10 years) |
General | |
Memory | |
Type | DRAM memory kit |
Technology | DDR4 SDRAM |
Form Factor | LRDIMM 288-pin |
Chips Organization | X4 |
Voltage | 1.2 V |
Miscellaneous | |
Colour Category | Green |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Germany - 10 years) |
