200-pin SODIMM
A small outline dual inline memory module (SODIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). SODIMMs get their name because they are smaller and thinner than regular DIMMs. The gold pins on the bottom of the SODIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a SODIMM are not connected.
200-pin SODIMMs are used to provide DDR and DDR2 SDRAM memory for notebook computers. 200-pin SODIMMs are available in PC2700 DDR SDRAM, PC3200 DDR SDRAM, DDR2 PC2-6400 SDRAM, DDR2 PC2-5300 SDRAM, DDR2 PC2-4200 SDRAM and DDR2 PC2-3200 SDRAM. To use DDR or DDR2 memory, your system motherboard must have 200-pin SODIMM slots and a DDR- or DDR2-enabled chipset. A DDR or DDR2 SODIMM will not fit into a standard SDRAM SODIMM socket. (Information about which memory technology your system uses is included in the Crucial Memory Advisor™ tool.)
The number of black components on a 200-pin SODIMM can vary, but it always has 100 pins on the front and 100 pins on the back, for a total of 200. 200-pin SODIMMs are approximately 2.625 inches long and 1.25 inches high, though the heights can vary. Like 144-pin SODIMMs, 200-pin SODIMMs have one small notch within the row of pins; however, the notch on the 200-pin SODIMMs is closer to the left side of the module.
Product Description | Crucial - DDR2 - module - 4 GB - SO-DIMM 200-pin - 800 MHz / PC2-6400 - unbuffered | Product Type | Memory module | Capacity | 4 GB | Memory Type | DDR2 SDRAM - SO-DIMM 200-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 800 MHz (PC2-6400) | Latency Timings | CL6 | Features | Unbuffered | Voltage | 1.8 V | Manufacturer Warranty | Limited lifetime warranty |
General | |
Capacity | 4 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR2 SDRAM |
Form Factor | SO-DIMM 200-pin |
Module Height (inch) | 1.25 |
Module Configuration | 512 x 64 |
Voltage | 1.8 V |
Expansion / Connectivity | |
Compatible Slots | 1 x memory - SO-DIMM 200-pin |
Miscellaneous | |
Colour Category | Black, green |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
