Marketing description is not available.
Product Description | Crucial - DDR4 - kit - 64 GB: 2 x 32 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - registered | Product Type | Memory kit | Capacity | 64 GB: 2 x 32 GB | Memory Type | DDR4 SDRAM - DIMM 288-pin | Upgrade Type | Generic | Data Integrity Check | ECC | Speed | 2666 MHz (PC4-21300) | Latency Timings | CL19 | Features | Dual rank, registered | Voltage | 1.2 V | Manufacturer Warranty | Limited lifetime warranty (Germany - 10 years) |
General | |
Memory | |
Type | DRAM memory kit |
Technology | DDR4 SDRAM |
Form Factor | DIMM 288-pin |
Chips Organization | X4 |
Voltage | 1.2 V |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Germany - 10 years) |
