Marketing description is not available.
Product Description | Crucial - DDR3 - kit - 8 GB: 2 x 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered | Product Type | Memory kit | Capacity | 8 GB: 2 x 4 GB | Memory Type | DDR3 SDRAM - SO-DIMM 204-pin | Upgrade Type | System specific | Data Integrity Check | Non-ECC | Speed | 1600 MHz (PC3-12800) | Latency Timings | CL11 | Features | Low Voltage, unbuffered | Voltage | 1.35 V | Manufacturer Warranty | Limited lifetime warranty | Designed For | Apple iMac 27" (Late 2013); iMac with Retina 5K display (Late 2014, Mid 2015); Mac mini (Late 2012); MacBook Pro (Mid 2012) |
General | |
Memory | |
Type | DRAM memory kit |
Technology | DDR3 SDRAM |
Form Factor | SO-DIMM 204-pin |
Module Height (inch) | 1.18 |
Voltage | 1.35 V |
Miscellaneous | |
Compliant Standards | Lead-Free, halogen-free |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
