Improved Dell Display Manager
Productive at every level: Dell Display Manager’s (DDM) Easy Arrange feature lets you quickly tile and view your applications side by side across one or more connected screens for multitasking efficiency. And with the improved DDM, you’ll get even more preset layouts.
Seamless transitions: The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you’ve unplugged.
The key to convenience: Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster.
More ways to manage: Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
All the essentials, and then some
Maximize your workspace: A thin profilei and improved cable management create a smaller footprint, lending itself to a clean, uncluttered desk.
Enhanced views: The 1366x768 resolution is ideal for everyday tasks, while ComfortView is ready for extended viewing periods. It reduces up to 60% of harmful blue light emissions.i
Versatile connections: Our E Series monitors accommodate legacy and non-legacy systems with convenient connectivity options like VGA and DP ports. Your workspace will be completely customized to your needs.
Adapts to your needs: Make your workspace your own with VESA-compatible mounts and stands.
Product Description | Dell E1920H - LED monitor - 19" | Device Type | LED-backlit LCD monitor - 19" | Energy Class | Class C | Power Consumption (On mode) | 8 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | 1366 x 768 at 60 Hz | Pixel Pitch | 0.3 mm | Brightness | 200 cd/m² | Contrast Ratio | 600:1 | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 72% (CIE 1931), 83% (CIE 1976) | Input Connectors | VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 44.54 cm x 17.1 cm x 35.96 cm | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified | Bundled Services | 3 years Advanced Exchange Service |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 19" |
Viewable Size | 18.5" |
Panel Type | TN |
Pixel Per Inch | 85 |
Horizontal Viewing Angle | 65 |
Vertical Viewing Angle | 90 |
Backlight Technology | LED backlight |
Features | ComfyView, Flicker Free technology |
Dimensions (WxDxH) | 44.54 cm x 17.1 cm x 35.96 cm - with stand |
Connectivity | |
Interfaces | DisplayPort 1.2 , VGA |
Mechanical | |
Tilt Angle | -5/+21 |
VESA Mounting Interface | 100 mm, VESA |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Included Accessories | VESA screw cover |
Cables Included | 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x VGA cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 8 kWh/1000h |
Power Consumption (Typical) | 10 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Software / System Requirements | |
Included Software | Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - weight: 2.19 kg , With stand - width: 44.54 cm - depth: 17.1 cm - height: 35.96 cm |
Dimensions & Weight (Shipping) | |
Shipping Weight | 3.92 kg |
Sustainability Information | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
