This reliable and affordable monitor meets everyday office demands. It has a great display quality at multiple angles with VESA-mount compatibility, as well as a VGA and DisplayPort. Save energy with power-efficient features.
Product Description | Dell E2216h - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (black-to-white) | Colour Support | 16.7 million colours | Colour Gamut | 72% (CIE 1931), 84% (CIE 1976) | Input Connectors | VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 51.22 cm x 18 cm x 39.67 cm | Weight | 3.36 kg | Microsoft Certification | Compatible with Windows 7 | Compliant Standards | Plug and Play, DDC/CI, RoHS, CECP | Manufacturer Warranty | 3-year warranty | Bundled Services | 3 years Advanced Exchange Service |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | TN |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Video Bandwidth | 148.5 MHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Controls & Adjustments | Brightness, contrast, H/V position, sharpness, phase, aspect control |
OSD Languages | Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish |
Features | Flicker Free technology, adjustable LED power indicator, Energy Gauge, backlight dimming control |
Colour | Black |
Dimensions (WxDxH) | 51.22 cm x 18 cm x 39.67 cm - with stand |
Weight | 3.36 kg |
Connectivity | |
Interfaces | DisplayPort , VGA |
Mechanical | |
Tilt Angle | -6/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, Dell Soundbar mounting slots |
Included Accessories | Stand, VESA screw cover |
Cables Included | 1 x DisplayPort cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 24 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities, Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 51.22 cm - depth: 18 cm - height: 39.67 cm - weight: 3.36 kg , Without stand - width: 51.22 cm - depth: 5.05 cm - height: 30.37 cm - weight: 2.84 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
