Revel in the superior screen performance of the Dell UltraSharp 24 monitor, loaded with premium features for an exceptional viewing experience, without the premium price tag.
Position your monitor to comfortably fit the way you work with a full range of tilt, pivot, swivel and height adjustments along with easy connections to your PC and peripherals.
Your Dell UltraSharp 24 Monitor - U2415 is designed to be pixel perfect. That's why if you find even just one bright pixel, we'll replace it under the Premium Panel Guarantee.
Product Description | Dell UltraSharp U2415 - LED monitor - 24.1" - with 3-years Premium Panel Exchange service | Device Type | LED-backlit LCD monitor - 24.1" | Energy Class | Class A+ | Energy Consumption per Year | 26 kWh | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:10 | Native Resolution | 1920 x 1200 at 60 Hz | Pixel Pitch | 0.27 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 2000000:1 (dynamic) | Response Time | 19 ms (black-to-white); 6 ms (grey-to-grey) | Colour Support | 16.8 million colours | Input Connectors | 2xHDMI (MHL), DisplayPort, Mini DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Colour | Black | Dimensions (WxDxH) - with stand | 53.22 cm x 20.5 cm x 40.29 cm | Weight | 6.35 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play | Manufacturer Warranty | 3-year warranty | Bundled with | 3-years Premium Panel Exchange service |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24.1" |
Viewable Size | 24.1" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Controls & Adjustments | Brightness, contrast, sharpness, saturation, gamma correction, rotation, input select, colour temperature, hue, aspect control |
Features | LED edgelight system, stand lock, 99% sRGB colour gamut, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Energy Saver, Premium Panel Guarantee, 91% (CIE 1976) colour gamut, 76% (CIE 1931) colour gamut, High Bit Rate 2 (HBR2) |
Colour | Black |
Dimensions (WxDxH) | 53.22 cm x 20.5 cm x 40.29 cm - with stand |
Weight | 6.35 kg |
Connectivity | |
Interfaces | 2 x MHL / HDMI , DisplayPort output (MST) , Mini DisplayPort , 5 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out , DisplayPort |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 115 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), LED indicator, integrated cable management |
Included Accessories | Stand, cable management cover |
Cables Included | 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Security Slot Type | Kensington security slot |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 65 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities, Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 53.22 cm - depth: 20.5 cm - height: 40.29 cm - weight: 6.35 kg , Without stand - width: 53.22 cm - depth: 4.57 cm - height: 35.06 cm - weight: 4.25 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
