See your work in beautiful Ultra HD 4K resolution on the large Dell UltraSharp monitor with PremierColor for exceptional color accuracy and professional standards.
Product Description | Dell UltraSharp UP3216Q - LED monitor - 32" | Device Type | LED-backlit LCD monitor - 32" | Energy Class | Class C | Energy Consumption per Year | 85 kWh | Power Consumption (On mode) | 58 W | Features | USB 3.0 hub, SD/MS/MMC card reader | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K UHD (2160p) 3840 x 2160 at 60 Hz | Pixel Pitch | 0.182 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 2000000:1 (dynamic) | Response Time | 6 ms | Colour Support | 1.07 billion colours | Colour Gamut | 87% DCI-P3, 100% Rec 709, 100% sRGB, 99.5% Adobe RGB | Input Connectors | HDMI (MHL), DisplayPort, Mini DisplayPort | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 74.99 cm x 21.4 cm x 48.26 cm | Weight | 11.2 kg | Compliant Standards | Plug and Play, VESA EDID, DDC/CI, RoHS | Manufacturer Warranty | 3-year warranty | Bundled Services | 3 years Advanced Exchange Service |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 32" |
Viewable Size | 31.5" |
Built-in Devices | USB 3.0 hub, SD/MS/MMC card reader |
Panel Type | IPS |
Vertical Refresh Rate | 24 - 75 Hz |
Horizontal Refresh Rate | 30 - 140 kHz |
Video Bandwidth | 533.25 MHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 5000K, 10000K |
Controls & Adjustments | Brightness, contrast, sharpness, saturation, gamma correction, input select, colour temperature, uniformity, hue, aspect control, colour space, gain, offset |
OSD Languages | Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese |
Features | Picture by picture, PremierColor technology, LED edgelight system, Picture-in-Picture Plus, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Premium Panel Guarantee, arsenic-free glass, Factory Calibration Report |
Colour | Black |
Dimensions (WxDxH) | 74.99 cm x 21.4 cm x 48.26 cm - with stand |
Weight | 11.2 kg |
Connectivity | |
Interfaces | DisplayPort , Mini DisplayPort , MHL / HDMI , 4 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Audio line-out |
Mechanical | |
Tilt Angle | -5.5/+22 |
Swivel Angle | 60 |
Height Adjustment | 90 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, 1 USB 3.0 charging port, Dell Soundbar mounting slots |
Included Accessories | Stand, cable management cover |
Cables Included | 1 x SuperSpeed USB cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m , 1 x Mobile High-Definition Link (MHL)-HDMI cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 130 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
On / Off Switch | No |
Software / System Requirements | |
Included Software | Display drivers, Dell Display Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 74.99 cm - depth: 21.4 cm - height: 48.26 cm - weight: 11.2 kg , Without stand - width: 74.99 cm - depth: 5.15 cm - height: 44.46 cm - weight: 8.6 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
