This interactive laser display solution eliminates the hassle and costs of maintenance while delivering impactful and collaborative meetings on a large scalable display to promote greater knowledge sharing and enhanced communication. Featuring finger-touch/dual-pen capability, Full HD WUXGA resolution, the ability to share two sources onto one display, and wireless and remote multi-location connectivity.
Product Description | Epson EB-1470Ui - 3LCD projector - ultra short-throw - 802.11b/g/n wireless / LAN / Miracast - white | Device Type | 3LCD projector - 1080p | Colour | White | Built-in Devices | Speaker | Brightness (White) | 4000 lumens | Brightness (Colour) | 4000 lumens | Contrast Ratio | 2500000:1 (dynamic) | Resolution | WUXGA (1920 x 1200) | Native Aspect Ratio | 16:10 | Colour Support | 1.07 billion colours | Lens | Ultra short-throw lens | Bulb type | Laser diode | Bulb life cycle | Up to 20000 hour(s) - normal mode , Up to 30000 hour(s) - economic mode | Video Input | RGB, S-Video IEEE 802.11b/g/n wireless / LAN / Miracast | Speakers | Speaker(s) - integrated | Power | AC 230V (50 - 60 Hz) | Power Consumption Operational | 448 Watt | Dimensions (WxDxH) | 49.4 cm x 43.7 cm x 17.2 cm | Weight | 11.4 kg |
General | |
Networking | 802.11b/g/n, Ethernet |
Enclosure Colour | White |
Projector | |
Brightness (Reduced) | 2800 lumens |
Image Size | 178 cm - 254 cm |
Projection Distance | 0.4 m - 0.6 m |
Throw Ratio | 0.27 - 0.37:1 |
Digital Zoom Factor | 1.35x |
Resolution | WUXGA - WUXGA (1920 x 1200) |
Features | sRGB colour profile, EPSON 3LCD technology, Whiteboard Mode, Split Screen, Direct Power On, Direct Power Off, Dynamic Mode |
Lens | |
Type | Ultra short-throw lens |
Focus Type | Manual |
Lens Aperture | F/1.6 |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -3 / +3 |
Horizontal Keystone Correction | -3 / +3 |
Video Input | |
Analogue video Signal | RGB, S-Video |
Video Interfaces | VGA, HDMI, S-Video, DVI, MHL |
LAN and Wireless Image Transferring Protocols | IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n, Miracast |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 16 Watt |
Speakers | 1 x mixed channel |
Expansion / Connectivity | |
Interfaces | 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDMI input - 19 pin HDMI Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x Sync in , 1 x Sync out , 1 x DVI-D output |
Miscellaneous | |
Included Accessories | Wall mounting kit, remote control, wireless LAN unit, pen case, finger touch unit, interactive pens, pen tips |
Cables Included | 1 x USB cable |
Mounting Kit | Included |
Power | |
Power Source | AC |
Voltage Required | AC 230V (50 - 60 Hz) |
Power Consumption Stand by | 2 Watt |
Software / System Requirements | |
Software Included | Epson Easy Interactive Tools, EasyMP Multi PC Projection |
Dimensions & Weight | |
Width | 49.4 cm |
Depth | 43.7 cm |
Height | 17.2 cm |
Weight | 11.4 kg |
Environmental Parameters | |
Sound Emission | 38 dBA |
Sound Emission (Economic Mode) | 27 dBA |
