Outstanding quality display of up to 260 inches
Full HD resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer presentations delivered on a scalable image size of up to 260 inches.
Simple setup and multiple connectivity
The EB-2245U offers a wide range of connectivity options, including screen mirroring, wireless LAN and two HDMI inputs. Setup is easy too, thanks to features including auto-power-on, focus help, keystone correction and screen fit - delivering presentations quickly and efficiently.
Home screen
The home screen offers quick and easy access to a variety of useful functions, such as connection sources. Wireless connections can also be made easily using the information on screen.
Gesture Presenter
Change slides by simply moving your hand, making even smarter presentations a reality by liberating the user from their remote control or mouse.
Value-added flexibility
The Multi-PC projection software bundled with the EB-2245U makes it possible to connect up to 50 computers and partition the screen for split-screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
Product Description | Epson EB-2245U - LCD projector - 802.11n wireless / LAN - white | Device Type | LCD projector - 1080p | Colour | White | Brightness (White) | 4200 lumens | Brightness (Colour) | 4200 lumens | Contrast Ratio | 400:1 / 15000:1 (dynamic) | Resolution | WUXGA (1920 x 1200) | Native Aspect Ratio | 16:10 | Colour Support | 1.07 billion colours | Bulb type | 300 Watt | Bulb life cycle | Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode | Video Input | RGB, composite video IEEE 802.11n wireless / LAN | Speakers | Speaker(s) - integrated | Power | AC 230V (50 - 60 Hz) | Power Consumption Operational | 410 Watt | Dimensions (WxDxH) | 37.7 cm x 29.1 cm x 11 cm | Weight | 4.8 kg | Manufacturer Warranty | 3-year warranty |
General | |
Networking | 802.11b/g/n, Ethernet |
Enclosure Colour | White |
Projector | |
Brightness (Reduced) | 3100 lumens |
Image Size | 114 cm - 660 cm |
Projection Distance | 1.5 m - 8.9 m |
Throw Ratio | 1.57 - 2.58:1 |
Resolution | WUXGA - WUXGA (1920 x 1200) |
Features | sRGB colour profile, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, instant on/off |
Lens | |
Focus Type | Manual |
Lens Aperture | F/1.5-2.0 |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -30 / +30 |
Horizontal Keystone Correction | -30 / +30 |
Video Input | |
Analogue video Signal | RGB, composite video |
Video Interfaces | VGA, HDMI, DisplayPort, composite video, MHL |
LAN and Wireless Image Transferring Protocols | IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 16 Watt |
Speakers | 1 x mixed channel |
Expansion / Connectivity | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort - 20 pin DisplayPort , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI |
Miscellaneous | |
Included Accessories | Wireless remote control, wireless LAN unit |
Cables Included | 1 x VGA cable |
Security Features | Security lock slot (cable lock sold separately), password protection |
Power | |
Power Source | AC |
Voltage Required | AC 230V (50 - 60 Hz) |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Software Included | EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection |
Dimensions & Weight | |
Width | 37.7 cm |
Depth | 29.1 cm |
Height | 11 cm |
Weight | 4.8 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
Sound Emission | 37 dBA |
Sound Emission (Economic Mode) | 29 dBA |
