Epson EB-945H 3000 Lumens XGA LCD Projector
Key features
  • Small and light enough to be carried and used across several rooms
  • 3LCD technology and equally high 3,000lm White and Colour Light Output
  • Horizontal and vertical keystone correction and optical zoom for flexible placement
  • Long lamp life; A/V mute function pauses presentation and conserves power by 70%
Product codes
chevron icon
chevron icon
The EB-945H uses 3LCD technology and an equally high White and Colour Light Output to deliver exceptional image quality and accurate colours. A 10,000:1 contrast ratio produces clearer image detail.
Epson understands that being in control is important when presenting in a corporate or education environment. The EB-945H comes with multi-PC projection software, which allows content from up to four devices, including PCs, tablets and smartphones, to be displayed simultaneously. The moderator function allows the host, whether it is the teacher, lecturer or leader of the meeting, to take control of displayed content from the devices.
Set up is easy and flexible with horizontal and vertical keystone correction, helping you achieve a perfectly shaped image without distortion. This means projectors can be quickly moved and set up in different classrooms and meeting rooms.
This projector has enhanced connectivity, giving choice and flexibility however you intend to present. The EB-945H can connect to the latest digital devices or legacy analogue products, meaning older hardware doesn't necessarily need to be replaced. Connecting smart devices couldn't be easier with the iProjection QR code connectivity - simply scan a projected QR code using your smart device to connect and start working.
chevron icon
Product Description Epson EB-945H - 3LCD projector - portable - LAN
Device Type 3LCD projector
Built-in Devices Speaker
Brightness (White) 3000 lumens
Brightness (Colour) 3000 lumens
Contrast Ratio 10000:1 (dynamic)
Resolution XGA (1024 x 768)
Native Aspect Ratio 4:3
Colour Support 1.07 billion colours
Bulb type 287 Watt
Bulb life cycle Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB, S-Video, composite video LAN
Speakers Speaker(s) - integrated
Power AC 120/230 V (50 - 60 Hz)
Power Consumption Operational 287 Watt
Dimensions (WxDxH) 29.7 cm x 26.9 cm x 8.7 cm
Weight 2.9 kg
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
