Experience remarkable detail on the large-screened, Full HD N246v 23.8-inch Monitor with a sharp 1920 x 1080 resolution and wide viewing angles. The vibrant views, convenient connectivity, adaptability, and affordable price point are ideal for everyday business.
Product Description | HP N246v - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class A+ | Energy Consumption per Year | 27 kWh | Power Consumption (On mode) | 19 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.275 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 10000000:1 (dynamic) | Response Time | 5 ms (overdrive) | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC | Input Connectors | HDMI, DVI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 54.66 cm x 20.99 cm x 40.51 cm | Weight | 3.65 kg | Localisation | English / United Kingdom | Compliant Standards | Plug and Play, TUV, CB, CCC, WEEE, CECP, CEL, SEPA |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Panel Type | IPS |
Pixel Per Inch | 93 |
Vertical Refresh Rate | 50 - 60 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Colour Temperature | 6500K |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | HDCP, Mercury free, arsenic free, 72% NTSC colour gamut |
Colour | Black |
Dimensions (WxDxH) | 54.66 cm x 20.99 cm x 40.51 cm - with stand |
Weight | 3.65 kg |
Connectivity | |
Interfaces | VGA , HDMI (HDCP) , DVI |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand, VESA interface support |
Cables Included | 1 x VGA cable - 1.5 m |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 22 Watt |
Power Consumption Sleep | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 54.66 cm - depth: 20.99 cm - height: 40.51 cm - weight: 3.65 kg , Without stand - width: 54.66 cm - depth: 4.47 cm - height: 32.1 cm - weight: 3.3 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 60.7 cm |
Shipping Depth | 12.5 cm |
Shipping Height | 40.5 cm |
Shipping Weight | 3.65 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
