Be a productive powerhouse with the sleek HP Z23n G2 58.42 cm (23") Display. This virtually seamless Full HD display is factory-tested for reliability and longevity with integrated color calibration, uninterrupted multi-screen tiling, and expansive device connections.
Product Description | HP Z23n G2 - LED monitor - Full HD (1080p) - 23" - Smart Buy | Device Type | LED-backlit LCD monitor - 23" | Energy Class | Class E | Energy Consumption per Year | 31 kWh | Power Consumption (On mode) | 17 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.2652 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 10000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 94% sRGB | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black Pearl | Dimensions (WxDxH) - without stand | 52.1 cm x 4.33 cm x 31.17 cm | Weight | 3.3 kg | Localisation | English / United Kingdom | Manufacturer Selling Program | HP Smart Buy | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, E-Standby, KC, ERP, CEL, CEL Grade 1, ISC, RCM, MSIP, SEPA, CoC, low halogen, CU, SmartWay | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Pixel Per Inch | 96 |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 30 - 84 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 6500K |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | Zero Bright Dot, HDCP, On-screen Digital Controls, Hard Coating (3H), slim bezel design, Mercury free, Factory Calibration, arsenic-free glass, Micro Edge |
Dimensions (WxDxH) | 52.1 cm x 4.33 cm x 31.17 cm - without stand |
Weight | 3.3 kg |
Connectivity | |
Interfaces | VGA , HDMI (HDCP) , DisplayPort (HDCP) , USB 3.0 upstream , 2 x USB 3.0 downstream |
Mechanical | |
Tilt Angle | -5/+22 |
Swivel Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand, VESA 100 x 100 mm |
Cables Included | 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 2 m , 1 x power cable - 1.9 m |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 17 kWh/1000h |
Power Consumption (Typical) | 18 Watt |
Power Consumption Stand by | 0.5 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
Included Software | HP Display Assistant |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 52.1 cm - depth: 4.33 cm - height: 31.17 cm - weight: 3.3 kg , With stand - width: 52.1 cm - depth: 20.5 cm - height: 45.8 cm - weight: 5.9 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 60.2 cm |
Shipping Depth | 26.5 cm |
Shipping Height | 39 cm |
Shipping Weight | 8.4 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
