The ProLite E2482HD is an excellent 24" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 5 ms response time and advanced contrast ratio, assuring clear and vibrant picture quality and high contrast. The E2482HD is also Energy Star certified. This monitor is a reliable solution for both home and office use.
Product Description | iiyama ProLite E2482HD - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class B | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.277 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 12000000:1 (dynamic) | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 56.55 cm x 20.3 cm x 41.2 cm | Weight | 3.3 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, TUV GS, DDC-2B, VESA DPMS, VCCI Class B |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Panel Type | TN |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
Controls & Adjustments | Brightness, contrast, H/V position, sharpness, input select, phase, luminance |
OSD Languages | Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese |
Features | HDCP, Eco-Mode, Advanced Contrast Ratio (ACR) |
Colour | Black |
Weight | 3.3 kg |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) |
Mechanical | |
Tilt Angle | -5/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Stand |
Cables Included | 1 x DVI cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 24 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | Driver |
OS Required | Microsoft Windows 95/98/ME/2000/XP/Vista/7/8 |
Sustainability Information | |
ENERGY STAR Certified | Yes |
