Looking for the perfect monitor? Choose the all-around IPS panel technology guaranteeing perfect color reproduction with wide viewing angles. Meeting the demands of both graphic design and the modern work place, the XB3270QS with a high resolution offers the perfect solution for productivity, design and data analysis. The height-adjustable stand ensures you can adjust the screen position to your preferences, and the flicker-free panel with blue light reducer function reduces eye fatigue.
Product Description | iiyama ProLite XB3270QS-B1 - LED monitor - 32" | Device Type | LED-backlit LCD monitor - 32" | Energy Class | Class G | Energy Consumption per Year | 93 kWh | Power Consumption (On mode) | 32.8 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | WQHD 2560 x 1440 at 60 Hz | Pixel Pitch | 0.273 mm | Brightness | 300 cd/m² | Contrast Ratio | 1200:1 / 80000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 1.07 billion colours | Input Connectors | HDMI, DVI, DisplayPort | Display Position Adjustments | Height, swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 73 cm x 23 cm x 44.45 cm | Weight | 8.9 kg | Compliant Standards | DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B, CU | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 32" |
Viewable Size | 31.5" |
Panel Type | IPS |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 30 - 90 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Czech, English, German, French, Italian, Polish, Russian, Japanese, Chinese |
Features | Picture in picture, HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, blue light reduction, i-Style Color |
Colour | Black |
Weight | 8.9 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 3 Watt |
Connectivity | |
Interfaces | DisplayPort , HDMI , Headphones , DVI |
Mechanical | |
Tilt Angle | -3/+22 |
Swivel Angle | 90 |
Height Adjustment | 100 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Headphone cable hook |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 32.8 kWh/1000h |
Power Consumption (Typical) | 57 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
