The ProLite T1531SAW uses highly accurate surface acoustic wave touch technology (SAW) with a pure-glass scratch resistive front, offering superior image clarity and screen durability. The screen can be touched with a soft stylus, finger or gloved hand making it suitable for a number of applications, and the robust design and solid but flexible stand ensures resilience in demanding environments. Menu buttons are located on the side of the screen which can be locked to prevent tampering, and include a handy function to deactivate the touch screen for cleaning . The Iiyama Prolite T1531SAW1 touch screen is ideal for a wide range of applications including POS, kiosks, hospitality and entertainment, control rooms, education, training and many others.
Product Description | iiyama ProLite T1531SAW-B3 - LED monitor - 15" | Device Type | LED-backlit LCD monitor - 15" - touchscreen | Features | Touch-screen | Panel Type | TN | Aspect Ratio | 4:3 | Native Resolution | 1024 x 768 | Pixel Pitch | 0.297 mm | Contrast Ratio | 700:1 | Response Time | 8 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Tilt | Screen Coating | 8H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 35.1 cm x 20.1 cm x 30.6 cm | Weight | 4.8 kg | Compliant Standards | VCCI, DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart, CU |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 15" |
Panel Type | TN |
Brightness w/touchscreen | 320 cd/m² |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 31.5 - 60.2 kHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
Controls & Adjustments | Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese |
Features | Scratch-resistant |
Colour | Black |
Weight | 4.8 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Surface acoustic wave |
Connectivity | |
Interfaces | VGA , DVI-D , USB , Serial , Audio line-in |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable , 1 x serial cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 20 Watt |
Power Consumption Stand by | 3 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
OS Required | Microsoft Windows 95, Microsoft Windows 98, Microsoft Windows NT 4.0, Microsoft Windows CE, Linux, Apple MacOS 9, Apple MacOS X, FreeDOS, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 |
