The ProLite T1732MSC 17" multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The Anti Glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree positioning angles. Menu Buttons are located on the side of the screen which can be locked to prevent tampering and includes a handy function to deactivate the TouchScreen for cleaning. In addition the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
Product Description | iiyama ProLite T1732MSC-B1AG - LCD monitor - 17" | Device Type | LCD monitor - 17" - touchscreen | Features | Touch-screen | Panel Type | TN | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 | Pixel Pitch | 0.264 mm | Brightness | 225 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (black-to-white) | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Tilt | Screen Coating | 7H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 38.7 cm x 20.2 cm x 34.2 cm | Weight | 5.6 kg | Compliant Standards | VCCI, VESA DPMS, CB, cULus, IP54, TUV Bauart |
General | |
Display Type | LCD monitor / TFT active matrix |
Diagonal Size | 17" |
Panel Type | TN |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 31.4 - 60 kHz |
Horizontal Viewing Angle | +80 / -80 |
Vertical Viewing Angle | +80 / -80 |
Controls & Adjustments | Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese |
Features | A-Si technology |
Colour | Black |
Dimensions (WxDxH) | 38.7 cm x 20.2 cm x 34.2 cm - with stand |
Weight | 5.6 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | VGA , DVI-D , USB , Audio line-in |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 20 Watt |
Power Consumption Stand by | 2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 38.7 cm - depth: 5.45 cm - height: 32 cm , With stand - width: 38.7 cm - depth: 20.2 cm - height: 34.2 cm - weight: 5.6 kg |
