Iiyama ProLite T1931SR-B5 19" touchscreen LED Monitor - 1280 x 1024 - TN - 250 cd/m² - 1000:1 - 5 ms - HDMI, VGA, DisplayPort with speakers in matte black
Product Description | iiyama ProLite T1931SR-B5 - LED monitor - 19" | Device Type | LED-backlit LCD monitor - 19" - touchscreen | Energy Class | Class E | Energy Consumption per Year | 27 kWh | Power Consumption (On mode) | 14.2 W | Features | Touch-screen, stylus | Panel Type | TN | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 at 75 Hz | Pixel Pitch | 0.294 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Matte black | Dimensions (WxDxH) | 43.2 cm x 21.8 cm x 39 cm | Weight | 6.6 kg | Compliant Standards | Plug and Play, VCCI, GOST, DDC-2B, CB, IP54, TUV Bauart | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 19" |
Panel Type | TN |
Brightness w/touchscreen | 200 cd/m² |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 31 - 80 KHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Italian, Spanish, Japanese, Chinese |
Features | Cable management cover, HDCP, 5-Wire Resistive Touch Screen Technology |
Weight | 6.6 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Input | |
Type | Touch-screen, stylus - touchscreen |
Movement Detection Technology | Resistive |
Connectivity | |
Interfaces | VGA , HDMI , DisplayPort , USB , Audio line-in |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x USB cable , 1 x HDMI cable , 1 x audio cable , 1 x DisplayPort cable |
Mounting Kit | Included |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 14.2 kWh/1000h |
Power Consumption (Typical) | 20 Watt |
Power Consumption Stand by | 2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
