iiyama ProLite T1931SR-W1 19" 1280x1024 5ms DVI USB Touchscreen LCD Monitor
Product codes
chevron icon
chevron icon
ProLite 1931SR is based on the 5 Wire Resistive technology. Price/performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both analog and digital (DVI) with touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree angles. Extensive touch utilities allow for 4 point calibration and either 9/25 point linearization.
chevron icon
Product Description iiyama ProLite T1931SR-W1 - LCD monitor - 19"
Device Type LCD monitor - 19" - touchscreen
Features Touch-screen, stereo speakers
Panel Type TN
Aspect Ratio 5:4
Native Resolution 1280 x 1024
Pixel Pitch 0.294 mm
Brightness 200 cd/m²
Contrast Ratio 900:1
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Speakers Integrated
Display Position Adjustments Tilt
Voltage AC 120/230 V (50/60 Hz)
Colour White
Dimensions (WxDxH) 43.1 cm x 39.1 cm x 21.8 cm
Weight 6.5 kg
Compliant Standards Plug and Play, FCC Class B certified, UL, TUV, VCCI Class B ITE, cUL
chevron icon
Accessories
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
