iiyama ProLite T2234MSC-B3X 22" 1920 x 1080 8ms VGA DVI Monitor
Key features
  • Scratch resistance
  • High quality stereo speakers
  • Touch technology
  • IPS technology
  • Full HD
Product codes
chevron icon
chevron icon
ProLite T2234MSC uses Projective Capacitive Touch Technology, built into an eye catching bezel with edge-to-edge glass. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for Interactive digital signage. In addition to the superb Full HD image quality, the screen is suitable for demanding environments. It comes with a rugged bezel, which means it is dust and water resistant.
chevron icon
Product Description iiyama ProLite T2234MSC-B3X - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22" - touchscreen
Features Touch-screen
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.247 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Display Position Adjustments Tilt
Screen Coating 6H Hard Coating
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) - with stand 51.75 cm x 21.9 cm x 35.15 cm
Weight 7.2 kg
Compliant Standards VCCI, DDC-2B, VESA DPMS, cULus, TUV Bauart, IP65, CU
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
