ProLite TF2234MC uses PCAP touch technology and is built into an eye catching bezel with edge-to-edge glass. Featuring IPS LCD Screen technology, it offers exceptional color performance and wide viewing angles. The higher brightness ensures crispy and clear images, even in a bright environment. In addition to the superb image quality, the screen is suitable for demanding environments. It comes with a rugged bezel and IP65 rating, meaning the monitor is dust and water resistant from the front. The Anti Glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. ProLite TF2234MC is the ideal screen for the kiosk integrators and a solution for Interactive Digital Signage, Instore Retail and Interactive Presentations.
Product Description | iiyama ProLite TF2234MC-B3AGB - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" - touchscreen | Features | Touch-screen | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.247 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 | Response Time | 8 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Screen Coating | Anti-glare, 6H Hard Coating | Colour | Black | Dimensions (WxDxH) | 51.75 cm x 4.6 cm x 31.35 cm | Weight | 4.4 kg | Compliant Standards | VCCI, VESA DPMS, cULus, TUV Bauart, IP65, CU, VESA DDC 2 B |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | IPS |
Brightness w/touchscreen | 290 cd/m² |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 31.5 - 82.3 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese |
Features | HighBrightness, edge-to-edge glass, HID Compliant, scratch-resistant, Projected Capacitive Touch (PCT) technology, Wide Viewing Angle |
Colour | Black |
Weight | 4.4 kg |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | DVI-D , VGA , USB |
Mechanical | |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Landscape / portrait mounting |
Cables Included | 1 x VGA cable , 1 x DVI cable , 1 x USB cable |
Mounting Kit | Included |
Power | |
Power Consumption (Typical) | 27 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
