ProLite TF2234MC uses Projective Capacitive Touch technology, built into an eye catching bezel with edge-to-edge glass. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for interactive digital signage. In addition to the superb image quality, the screen is dust and water resistant, equipped with a rugged bezel making it suitable for demanding environments. The ProLite TF2234MC is the ideal screen for the kiosk integrators and a solution for interactive digital signage, instore retail, gaming and interactive presentations.
Product Description | iiyama ProLite TF2234MC-B3X - LED monitor - 22" | Device Type | LED-backlit LCD monitor - 22" - touchscreen | Features | Touch-screen | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD 1920 x 1080 | Pixel Pitch | 0.247 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 8 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Screen Coating | 6H Hard Coating | Colour | Black | Dimensions (WxDxH) | 51.75 cm x 4.6 cm x 31.35 cm | Weight | 4.4 kg | Compliant Standards | VCCI, VESA DPMS, cULus, TUV Bauart, IP65, CU |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | IPS |
Brightness w/touchscreen | 220 cd/m² |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 31.5 - 82.3 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese |
Features | HID Compliant, scratch-resistant, Projected Capacitive Touch (PCT) technology |
Colour | Black |
Weight | 4.4 kg |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | DVI-D , VGA , USB |
Mechanical | |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x VGA cable , 1 x DVI cable , 1 x USB cable |
Mounting Kit | Included |
Power | |
Power Consumption (Typical) | 27 Watt |
Power Consumption Stand by | 2 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
