The ProLite TF2234MC uses PCAP touch technology, and it is built into an eye-catching bezel with edge-to-edge glass. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angles. The higher brightness ensures crispy and clear images, even in a bright environment. In addition to the superb image quality, the screen is suitable for demanding environments. It comes with a rugged bezel and IP65 rating, meaning the monitor is dust and water resistant from the front. The Anti Glare coating helps to avoid issues with reflections and external light sources affecting contrast and sharpness. The ProLite TF2234MC is the ideal screen for kiosk integrators and a superb display for use as interactive digital signage, instore retail and interactive presentation display.
Product Description | iiyama ProLite TF2234MC-B6AGB - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" - touchscreen | Energy Class | Class F | Power Consumption (On mode) | 18.9 W | Features | Touch-screen | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.247 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 | Response Time | 8 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort | Screen Coating | Anti-glare, 6H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 51.75 cm x 4.6 cm x 31.35 cm | Weight | 4.4 kg | Compliant Standards | Plug and Play, VCCI, DDC-2B, cULus, TUV Bauart, IP65, CU, REACH SvHC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | IPS |
Brightness w/touchscreen | 300 cd/m² |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 84 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese |
Features | HighBrightness, HDCP, anti-reflective, 10-point multi-touch |
Colour | Black |
Weight | 4.4 kg |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | DisplayPort , VGA , HDMI , USB |
Mechanical | |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Landscape / portrait mounting, front IP65 protection |
Cables Included | 1 x HDMI cable - 1.8 m , 1 x display cable - 1.8 m , 1 x USB cable - 1.8 m |
Mounting Kit | Included |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 18.9 kWh/1000h |
Power Consumption (Typical) | 18 Watt |
Power Consumption Stand by | 1 Watt |
Power Consumption (Off Mode) | 1 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
