ProLite X2485WS features an IPS technology LED panel offering accurate and consistent color reproduction with wide viewing angles and fast response time. The ProLite X2485WS is a 16:10 monitor with 1920 x 1200 native screen resolution. An array of inputs including Display Port, DVI and VGA connections ensure compatibility across a range of devices including games consoles and work stations. It also has two integrated stereo speakers and is VESA mount compatible.
Product Description | iiyama ProLite X2485WS-B3 - LED monitor - 24.1" | Device Type | LED-backlit LCD monitor - 24.1" | Panel Type | IPS | Aspect Ratio | 16:10 | Native Resolution | 1920 x 1200 | Pixel Pitch | 0.27 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA, DisplayPort | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 56.1 cm x 21.65 cm x 44.9 cm | Weight | 4.8 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, TUV GS, DDC-2B, VESA DPMS, VCCI Class B, CU |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24.1" |
Panel Type | IPS |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 30 - 94 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | English, German, French, Italian, Russian, Spanish, Dutch, Japanese, Chinese |
Features | Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), blue light reduction |
Colour | Black |
Dimensions (WxDxH) | 56.1 cm x 21.65 cm x 44.9 cm - with stand |
Weight | 4.8 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1.5 Watt |
Connectivity | |
Interfaces | VGA , DVI-D , DisplayPort , Headphones |
Mechanical | |
Tilt Angle | -5/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Stand |
Cables Included | 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 24 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | Driver |
OS Required | Microsoft Windows 95/98/ME/2000/XP/Vista/7/8/10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 56.1 cm - depth: 21.65 cm - height: 44.9 cm - weight: 4.8 kg , Without stand - width: 56.1 cm - depth: 5.1 cm - height: 38 cm |
Sustainability Information | |
ENERGY STAR Certified | Yes |
