The ProLite XU292HS featuring IPS technology guarantees accurate and consistent color reproduction with wide viewing angles. Triple input configuration (VGA, HDMI, DisplayPort) assures compatibility with many platforms.
Product Description | iiyama ProLite XU2292HS-B1 - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" | Energy Class | Class E | Energy Consumption per Year | 24 kWh | Power Consumption (On mode) | 13.7 W | Features | USB 2.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz) | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 80000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC, 99% sRGB | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Matte | Voltage | AC 120/230 V (50/60 Hz) | Colour | Matte black | Dimensions (WxDxH) | 48.85 cm x 18.7 cm x 37.6 cm | Weight | 3.2 kg | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified | Compliant Standards | TUV GS, DDC-2B, PSE Mark, REACH, VCCI Class B, CU, REACH SvHC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Built-in Devices | USB 2.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 30 - 85 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese |
Features | Ultra Slim Design, HDCP, Eco-Mode, High Frame Rate Control (Hi-FRC), Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color, 8-bit gamma, 72% NTSC colour gamut, 99% sRGB colour gamut |
Weight | 3.2 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Connectivity | |
Interfaces | VGA , HDMI (HDCP) , DisplayPort , Headphones (mini-jack) |
Mechanical | |
Tilt Angle | -5/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 13.7 kWh/1000h |
Power Consumption (Typical) | 18 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.26 Watt |
Sustainability Information | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
