Stylish ultra-flat front design makes the ProLite perfect for multi-monitor set-ups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles and the WQHD (2560 x 1440) resolution means the XUB2792QSU can accommodate more information on the screen. High contrast and brightness values enable the monitor will provide excellent performance for photographic and web design, and the height-adjustable stand ensures you can easily adjust the screen position to your preferences. It is a great choice for both multi-monitor digital signage and office applications.
Product Description | iiyama ProLite XUB2792QSU-B1 - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class G | Energy Consumption per Year | 50 kWh | Power Consumption (On mode) | 29.7 W | Adaptive-Sync Technology | AMD FreeSync | Features | USB 3.0 hub | Panel Type | AH-IPS | Aspect Ratio | 16:9 | Native Resolution | 2560 x 1440 at 70 Hz | Pixel Pitch | 0.233 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 5 ms | Colour Support | 1.07 billion colours | Input Connectors | HDMI, DVI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 61.1 cm x 23 cm x 39.7 cm | Weight | 6.1 kg | Environmental Standards | TCO Certified Displays 7, ENERGY STAR Qualified | Compliant Standards | TUV GS, DDC-2B, VESA DPMS, CU | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB 3.0 hub |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 30 - 89 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese |
Features | Matte, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color |
Colour | Black |
Weight | 6.1 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | DVI , HDMI , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , Audio line-out (mini-jack) |
Mechanical | |
Tilt Angle | -5/22 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 29.7 kWh/1000h |
Power Consumption (Typical) | 33 Watt |
Sustainability Information | |
TCO Certified | TCO Certified Displays 7 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
