The ThinkVision T25d with its 25-inch NearEgdeless In-Plane Switching screen redefines visual clarity. The 16:10 aspect ratio with 11% more pixels than full-HD offer more screen real estate for seamless multitasking. Versatile HDMI, DisplayPort, and legacy VGA ports enable easy connectivity to your favorite work essentials. Impressive 4ms response time minimizes motion blur, allowing you to enjoy smooth, flicker-free visuals from any angle. Well suited for number crunching, or graphic designing, the ThinkVision T25d monitor is a smart investment for professionals whose job role requires them to be more detail-oriented
Product Description | Lenovo ThinkVision T25d-10 - LED monitor - 25" | Device Type | LED-backlit LCD monitor - 25" | Energy Class | Class D | Power Consumption (On mode) | 15.8 W | Features | USB 3.1 Gen 1 hub | Panel Type | IPS | Aspect Ratio | 16:10 | Native Resolution | 1920 x 1200 at 60 Hz | Pixel Pitch | 0.2823 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 3000000:1 (dynamic) | Response Time | 4 ms (extreme), 6 ms (typical) | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 100 - 240 V (50 - 60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 54.87 cm x 26.04 cm x 39.95 cm | Weight | 5.5 kg | Localisation | English / United Kingdom | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified | Compliant Standards | CCC, UL Environmental SPC Gold, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification, EU RoHS, ULE Gold | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 25" |
Built-in Devices | USB 3.1 Gen 1 hub |
Panel Type | IPS |
Pixel Per Inch | 91 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | Anti-glare, 99% sRGB colour gamut |
Colour | Black |
Dimensions (WxDxH) | 54.87 cm x 26.04 cm x 39.95 cm - with stand |
Weight | 5.5 kg |
Connectivity | |
Interfaces | VGA (HD-15) , HDMI , DisplayPort , 4 x USB 3.1 Gen 1 , USB 3.1 Gen 1 , Audio line-out |
Mechanical | |
Tilt Angle | -5/+30 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 110 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100 - 240 V (50 - 60 Hz) |
Power Consumption SDR (On mode) | 15.8 kWh/1000h |
Power Consumption (Typical) | 25 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
OS Required | Microsoft Windows 7, Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 54.87 cm - depth: 26.04 cm - height: 39.95 cm - weight: 5.5 kg , Without stand - width: 54.87 cm - depth: 4.3 cm - height: 36.91 cm - weight: 3.58 kg |
Sustainability Information | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
