ITEM | QTY | PRICE |
Synology DX1215II 12 Bay Desktop NAS
3 | £2,636.19 |
Do more than just optimize your productivity with the ThinkVision T32h-20 monitor. Get an enhanced view of and easily navigate through documents, spreadsheets, or designs on this sleek display that complements your modern workspace. Its vast 31.5-inch screen with QHD resolution delivers more screen real estate with higher clarity than FHD, making data-intensive work, number crunching, and content editing a breeze. The one-cable solution USB Type-C, HDMI, and DP ports provide multiple interface options. Integrated with Smart Power the USB Type-C also doubles up as a charger for dynamic consumption and intelligent power management.
Product Description | Lenovo ThinkVision T32h-20 - LED monitor - 32" | Device Type | LED-backlit LCD monitor - 32" | Energy Class | Class E | Power Consumption (On mode) | 26.5 W | Features | USB 3.1 Gen 1 hub, USB PD 75 Watt | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 | Pixel Pitch | 0.2727 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 3000000:1 (dynamic) | Response Time | 14 ms, 6 ms, 4 ms (extreme mode) | Colour Support | 1.07 billion colours | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Raven black | Dimensions (WxDxH) - with stand | 71.46 cm x 23.5 cm x 46.94 cm | Weight | 9.85 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified EPEAT Silver | Compliant Standards | CCC, RoHS, DisplayPort 1.2, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 32" |
Built-in Devices | USB 3.1 Gen 1 hub |
USB Power Delivery | 75 Watt |
Panel Type | IPS |
Pixel Per Inch | 94 |
Vertical Refresh Rate | 60 Hz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | Integrated cable management, 3-side NearEdgeless, 99% sRGB colour gamut |
Dimensions (WxDxH) | 71.46 cm x 23.5 cm x 46.94 cm - with stand |
Weight | 9.85 kg |
Connectivity | |
Interfaces | DisplayPort , HDMI , Headphones , USB 3.1 Gen 1 downstream with Battery Charging , 3 x USB 3.1 Gen 1 downstream , USB-C 3.1 Gen 1 upstream/DisplayPort Alt Mode with Power Delivery (power up to 75W) |
Mechanical | |
Tilt Angle | -5/+35 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 135 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x USB-C cable - 1.8 m |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 26.5 kWh/1000h |
Power Consumption (Typical) | 28 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand (highest position) - width: 71.46 cm - depth: 23.5 cm - height: 60.44 cm - weight: 9.85 kg , With stand (lowest position) - width: 71.46 cm - depth: 23.5 cm - height: 46.94 cm - weight: 9.85 kg , Without stand - width: 71.46 cm - depth: 5.1 cm - height: 42.6 cm - weight: 6.78 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 84.5 cm |
Shipping Depth | 52.8 cm |
Shipping Height | 19 cm |
Shipping Weight | 12.96 kg |
Sustainability Information | |
EPEAT Compliant | EPEAT Silver |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 8.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
