Full HD Picture Quality
With clarify of 1080p Full HD, everything looks more detailed than standard HD and a lot more inviting on the LG 22MK400A.
OnScreen Control
LG 22MK400A OnScreen Control is simple and intuitive. You can customize your display options with a few simple clicks.
Reader Mode
Reducing blue light to help lessen eye fatigue, Reader Mode provides optimal condition for reading. With easy joystick control, you can more comfortably read your monitor screen.
Offers Stable Image
Reducing the flicker level to almost zero, Flicker-Safe helps you protect your eyes from exhausting flickers.
Dynamic Action Sync
Minimize input lag with Dynamic Action Sync so you can catch every single moment in real-time.
Black Stabilizer
You can avoid snipers hiding in the darkest places and quickly escape situations when the flash explodes.
Wall Mountable
This LG 22MK400A monitor gives you the freedom to take it off the desk and hang it on the wall. Liberate your viewing options and save desktop space with this wall-mountable LG monitor.
Product Description | LG 22MK400A-B - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" | Adaptive-Sync Technology | AMD FreeSync | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Brightness | 200 cd/m² | Contrast Ratio | 600:1 | Response Time | 5 ms | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC | Input Connectors | VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 51 cm x 18.2 cm x 36 cm | Weight | 2.4 kg |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | TN |
Horizontal Viewing Angle | 90 |
Vertical Viewing Angle | 65 |
Backlight Technology | LED backlight |
Features | Crosshair Display, Flicker Safe, Reader Mode, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Color Weakness Mode, Mega DFC, 72% NTSC colour gamut |
Colour | Black |
Dimensions (WxDxH) | 51 cm x 18.2 cm x 36 cm - with stand |
Weight | 2.4 kg |
Connectivity | |
Interfaces | VGA |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 75 x 75 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 19.7 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 51 cm - depth: 18.2 cm - height: 36 cm - weight: 2.4 kg , Without stand - width: 51 cm - depth: 3.8 cm - height: 30.6 cm - weight: 2.1 kg |
