High Definition with Accurate Colour
1080p Full HD resolution with IPS delivers brilliant images that pop with vibrant detail from any viewing angle.
Clearer, Smoother Image
AMD FreeSync™ Technology and a dynamic refresh rate of 75Hz virtually eliminates screen tearing and stuttering to bring you seamless, fluid movement during high-res, fast-paced games.
React Faster to The Action
Dynamic Action Sync mode allows you to instantly react to your opponents and attack them without any display lag. It synchronizes your senses with real-time scenes in fast-paced games by minimizing input lag.
Enemies Have Nowhere to Hide
Black Stabilizer gives you full visual clarity, even in games where you spend a lot of time in the dark. It synchronizes and brightens the darkest areas, so that you can find enemies hiding in the shadows and shoot first.
Easier User Interface
OnScreen Control is simple and intuitive. You can customise your display options with a few simple clicks.
Convenient and Flexible
Mount the monitor to suit your work or entertainment set up.
Product Description | LG 24MK430H-B - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class F | Energy Consumption per Year | 35 kWh | Power Consumption (On mode) | 24 W | Adaptive-Sync Technology | AMD FreeSync | Panel Type | AH-IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.2744 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Matte black | Dimensions (WxDxH) - with stand | 55.5 cm x 18.19 cm x 42.1 cm | Weight | 3.1 kg | Compliant Standards | FCC Class B certified, TUV, SEMKO |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.8" |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | Mega Dynamic Contrast Ratio, On-screen Digital Controls, Crosshair Display, Flicker Safe, Reader Mode, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), My Display Preset, Color Weakness Mode |
Dimensions (WxDxH) | 55.5 cm x 18.19 cm x 42.1 cm - with stand |
Weight | 3.1 kg |
Connectivity | |
Interfaces | HDMI , VGA , Audio line-out |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 75 x 75 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Cable holder |
Cables Included | 1 x HDMI cable - 1.8 m , 1 x VGA cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 20 kWh/1000h |
Power Consumption (Typical) | 30 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 55.5 cm - depth: 18.19 cm - height: 42.1 cm - weight: 3.1 kg , Without stand - width: 55.5 cm - depth: 3.84 cm - height: 33.09 cm - weight: 2.8 kg |
