This monitor features an Infinity display that provides a borderless visual experience for 4-side of the display for an all-inclusive view. Smoothness and solidness coexist in the curved structure - the beauty of ArcLine is the icing on the cake.
Product Description | LG 24MP88HV - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class E | Energy Consumption per Year | 28 kWh | Power Consumption (On mode) | 17.8 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Brightness | 250 cd/m² | Response Time | 5 ms | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB | Input Connectors | 2xHDMI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Colour | Silver spray with white back | Dimensions (WxDxH) - with stand | 54.1 cm x 18.62 cm x 41.45 cm | Weight | 3.2 kg | Compliant Standards | Plug and Play, FCC Class B certified, TUV, DDC/CI, ERP, EPA 6.0 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Picture in picture, split screen, Picture Mode, SUPER Energy Saving Technology, Flicker Safe, Reader Mode, SIX Axis Control, MaxxAudio, Smart Energy Saving technology, Color Calibrated, Black Stabilizer, My Display Preset, Color Weakness Mode, Mega DFC, 99% sRGB colour gamut |
Dimensions (WxDxH) | 54.1 cm x 18.62 cm x 41.45 cm - with stand |
Weight | 3.2 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Connectivity | |
Interfaces | VGA , 2 x HDMI , Headphones , Audio line-in |
Mechanical | |
Tilt Angle | -2/+15 |
VESA Mounting Interface | 75 x 75 mm |
Miscellaneous | |
Power | |
Power Consumption SDR (On mode) | 17.8 kWh/1000h |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
OS Required | Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 54.1 cm - depth: 18.62 cm - height: 41.45 cm - weight: 3.2 kg , Without stand - width: 54.1 cm - depth: 4.66 cm - height: 31.33 cm - weight: 2.9 kg |
