IPS (In-Plane Switching) technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle.
On-screen control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and dual controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor.
Product Description | LG 27MP38VQ-B - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class A | Energy Consumption per Year | 34 kWh | Power Consumption (On mode) | 23 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Brightness | 200 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Input Connectors | HDMI, DVI, VGA | Voltage | AC 120/230 V | Dimensions (WxDxH) - without stand | 64.14 cm x 4.82 cm x 39.3 cm | Weight | 3.9 kg | Compliant Standards | Plug and Play, DDC/CI | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | IPS |
Horizontal Refresh Rate | 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean |
Features | SUPER Energy Saving Technology, 4-screen split, Multilingual On Screen Display |
Dimensions (WxDxH) | 64.14 cm x 4.82 cm x 39.3 cm - without stand |
Weight | 3.9 kg |
Connectivity | |
Interfaces | VGA , HDMI , DVI-D , Headphones |
Mechanical | |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption (Typical) | 27 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 64.14 cm - depth: 4.82 cm - height: 39.3 cm - weight: 3.9 kg , With stand - width: 64.14 cm - depth: 20.3 cm - height: 45.97 cm - weight: 4.4 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
