To more fully realize content creators' vision, this monitor is compatible with industry-standard HDR10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors.
The HDR Effect helps transform non-HDR content into high quality video that looks like HDR through its picture quality algorithm.
Connect with confidence: this LG 4K monitor is compatible with the HDCP 2.2 copy protection, so it will display video from 4K streaming services, game consoles and Ultra HD Blu-ray disc players.
Product Description | LG 27UK650-W - LED monitor - 4K - 27" - HDR | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class A | Energy Consumption per Year | 44 kWh | Power Consumption (On mode) | 30 W | Adaptive-Sync Technology | AMD FreeSync | Panel Type | AH-IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.1557 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 | HDR Capable | HDR10 | Response Time | 5 ms (grey-to-grey) | Colour Support | 1.073 billion colours (8-bit) | Colour Gamut | 99% sRGB | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50 - 60 Hz) | Colour | Silver (stand), white (back), silver (front) | Dimensions (WxDxH) - with stand | 61.5 cm x 20.95 cm x 45.49 cm | Weight | 4.9 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | FCC Class B certified, UL, TUV, C-Tick, cUL, SEMKO, EN 61000-3-3, EN55024, CB, DDC/CI, RoHS, Directive 2004/108/CE, Directive 2006/95/EC, EN 61000-3-2:2006, EN 60950-1:2006, EPA 6.0, EN55022:2006 Class B, DisplayPort 1.2, HDCP 2.2 | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
HDR Format | HDR10 |
Vertical Refresh Rate | 56 - 61 Hz |
Horizontal Refresh Rate | 30 - 135 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | SUPER + Resolution, game mode, Mega Contrast, 4-screen split, Flicker Safe, Reader Mode, Factory Calibration, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Color Weakness Mode |
Dimensions (WxDxH) | 61.5 cm x 20.95 cm x 45.49 cm - with stand |
Weight | 4.9 kg |
Audio | |
Type | Headphone |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , Headphones |
Mechanical | |
Tilt Angle | -5/+15 |
Rotation Angle | 90 |
Height Adjustment | 110 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), mercury free |
Cables Included | HDMI cable , DisplayPort cable - 1.8 m |
Power | |
Input Voltage | AC 120/230 V (50 - 60 Hz) |
Power Consumption (Typical) | 40 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities, Dual Controller Software |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.5 cm - depth: 20.95 cm - height: 45.49 cm - weight: 4.9 kg , Without stand - width: 61.5 cm - depth: 4.94 cm - height: 36.51 cm - weight: 4.6 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 69.4 cm |
Shipping Depth | 16.05 cm |
Shipping Height | 44 cm |
Shipping Weight | 6.4 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
