You Want to Enjoy More UHD Contents
More and more streaming videos come in 4K, you want to enjoy millions of 4K streaming videos in native 3840x2160 UHD 4K resolution. You can also review your 4K contents before uploading them. You can appreciate the amount of detail you can enhance as LG UHD 4K Monitor delivers the outcome of your work.
HDCP 2.2 Compatible
Connect with confidence: This LG 4K monitor is compatible with the latest HDCP 2.2 copy protection, so it will display video from 4K streaming services, game consoles and Ultra HD Blu-ray disc players.
The LG IPS Monitor
The LG IPS Monitors ensures an awesome picture quality that provides clear images and vivid colours from any angle. Colour Calibration tests will be conducted before each product is handed over to you. Now you can enjoy the life-like colours of 4K images on LG IPS UHD 4K Monitor
4 Side Borderless Design & Slim ArcLine Stand
Extremely thin bezel on four sides of the display offers a borderless visual experience. Slim ArcLine designed stand lets you experience the state-of-the-art viewing in various settings.
Complete Your Multi-Dimensional Experience with
It delivers unparalleled immersive experience through the built-in speakers with Rich Bass. Enjoy three dimensional sound resonating from your monitor.
USB Type-C™
Offering a new generation of convenience, USB Type-C™ports allow 4K video display and laptop/mobile device charging, at the same time over a single cable. Reduce cord clutter and increase efficiency with USB Type-C™.
Easy User Interface with On Screen Control 2.0
Every step of installing and controlling is easy without any hassle. On Screen Control S/W (2.0) allows you adjust customize all the display options with a few clicks including pivot control.
Various Types of Screen Split Options with Click
Through On Screen Control Software, select most needed screen setting among 14 of Screen Split options and optimize Multi-tasking Windows organization and screen real estate use.
Easy Control of Pivoted Ergonomic Stand
Pivoted screen maximizes work efficiency of graphic works on vertical frames such as web editing and blogging. Simply rotate the screen as needed and view the display without scrolling. The height adjustment feature adds convenience. OnScreen Control S/W allows you to adjust and customize all the display options with a few clicks.
Product Description | LG 32UD89 - LED monitor - 4K - 31.5" | Device Type | LED-backlit LCD monitor - 31.5" | Energy Class | Class A | Energy Consumption per Year | 57 kWh | Power Consumption (On mode) | 39 W | Adaptive-Sync Technology | AMD FreeSync | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.18159 mm | Brightness | 350 cd/m² | Contrast Ratio | 1300:1 | Response Time | 5 ms (grey-to-grey) | Colour Gamut | 99% sRGB, 99% sRGB (CIE 1931) | Input Connectors | 2xHDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | White back cover and stand, silver spray front and base | Dimensions (WxDxH) - with stand | 71.38 cm x 25.92 cm x 48.54 cm | Weight | 8.8 kg | Compliant Standards | Plug and Play, FCC Class B certified, UL, TUV, cUL, CB, DDC/CI, RoHS, REACH, KC, ERP, EPA |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 31.5" |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 61 Hz |
Horizontal Refresh Rate | 30 - 135 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Korean |
Features | SUPER + Resolution, Black eQualizer, On-screen Digital Controls, Flicker Safe, Reader Mode, SIX Axis Control, Factory Calibration, Dual Controller, DAS Mode (Dynamic Action Sync), Mega DFC, Rich Bass, 4 Side Borderless Design, 99% sRGB colour gamut |
Dimensions (WxDxH) | 71.38 cm x 25.92 cm x 48.54 cm - with stand |
Weight | 8.8 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Connectivity | |
Interfaces | 2 x HDMI (HDCP) , DisplayPort , USB-C , Headphones , USB downstream |
Mechanical | |
Tilt Angle | -2/+15 |
Height Adjustment | 110 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | ArcLine stand |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C cable - 1.8 m |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 71.38 cm - depth: 25.92 cm - height: 48.54 cm - weight: 8.8 kg , Without stand - width: 71.38 cm - depth: 4.46 cm - height: 41.02 cm - weight: 6.5 kg |
