This IPS display offers amazingly sharp picture quality. This wide display is ideal for photographers, producers and other creative professionals who need more room for big ideas.
Product Description | LG 34UC99-W - LED monitor - curved - 34" | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class G | Energy Consumption per Year | 76 kWh | Power Consumption (On mode) | 52 W | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync | Features | USB 3.0 hub | Panel Type | AH-IPS | Aspect Ratio | 21:9 | Native Resolution | UWQHD 3440 x 1440 at 60 Hz | Pixel Pitch | 0.232 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 1.073 billion colours (8-bit) | Colour Gamut | 99% sRGB | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Height, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Grey, white | Dimensions (WxDxH) - with stand | 81.76 cm x 25.94 cm x 48.28 cm | Weight | 8.4 kg | Compliant Standards | Plug and Play, FCC Class B certified, UL, EN 61000-3-3, EN55024, EMC, DDC/CI, RoHS, Directive 2004/108/EC, Directive 2006/95/EC, EN 61000-3-2:2006, EN 60950-1:2006, EN55022:2006 Class B | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 34" |
Curved Screen | Yes (1900R) |
Built-in Devices | USB 3.0 hub |
Vertical Refresh Rate | 56 - 61 Hz |
Horizontal Refresh Rate | 30 - 90 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | Picture in picture, picture by picture, Picture Mode, game mode, Multiscan Support, On-screen Digital Controls, Flicker Safe, Reader Mode, Dual Link-up, SIX Axis Control, Factory Calibration, MaxxAudio, Smart Energy Saving technology, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), My Display Preset, Color Weakness Mode, Dark Room mode, USB 3.0 Quick Charge, 99% sRGB colour gamut |
Dimensions (WxDxH) | 81.76 cm x 25.94 cm x 48.28 cm - with stand |
Weight | 8.4 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 7 Watt |
Connectivity | |
Interfaces | USB-C , 2 x HDMI , DisplayPort , 2 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out |
Mechanical | |
Tilt Angle | -5/+15 |
Height Adjustment | 110 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Cable holder |
Cables Included | 1 x DisplayPort cable , 1 x HDMI cable , 1 x USB-C cable - 1 m , 1 x USB cable - USB Type A to C |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 40 kWh/1000h |
Power Consumption (Typical) | 70 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 81.76 cm - depth: 25.94 cm - height: 48.28 cm - weight: 8.4 kg , Without stand - width: 81.76 cm - depth: 8.87 cm - height: 36.08 cm - weight: 6.4 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
