HDR 10
To more fully realize content creators’ vision, this monitor is compatible with industry-standard HDR10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors.
HDR Effect
The HDR Effect helps transform non-HDR content into high quality video that looks like HDR through its picture quality algorithm.
IPS with sRGB 99% (Typ.)
This monitor, with 99% coverage of the sRGB spectrum, is a great solution for photographers, graphic designers or anyone looking for highly accurate color.
Virtually Borderless Design
The ultra-thin bezel on three sides of this streamlined display offers a virtually borderless visual experience, without distraction from the precise, gorgeous image. A sleek addition to any desktop.
21:9 UltraWide® Display
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
On-Screen Control
On-Screen Control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor.
AMD FreeSync™
With FreeSync*, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync virtually eliminates screen tearing and stuttering.
Advanced Gaming Features
Serious gaming features for serious gamers. Quickly optimize monitor settings to activate Black Stabilizer to reveal superior detail in dark scenes while the Dynamic Action Sync feature assures smooth, fluid gaming action.
Sleek Design
The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
Product Description | LG 34WK650 - LED monitor - 34" - HDR | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class G | Energy Consumption per Year | 55 kWh | Power Consumption (On mode) | 37.8 W | Adaptive-Sync Technology | AMD FreeSync | Panel Type | IPS | Aspect Ratio | 21:9 | Native Resolution | UWFHD 2560 x 1080 at 75 Hz | Pixel Pitch | 0.312 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 | HDR Capable | HDR10 | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Height, tilt | Voltage | AC 120/230 V | Colour | Black texture, white texture, silver hairline, textured silver | Dimensions (WxDxH) - with stand | 82.56 cm x 23 cm x 46.07 cm | Weight | 7.6 kg | Compliant Standards | FCC Class B certified, UL, TUV, VCCI, cUL, CCC, DDC/CI, ERP, EPA 7.0, HDCP 2.2, HDCP 1.4 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 34" |
Panel Type | IPS |
HDR Format | HDR10 |
Vertical Refresh Rate | 40 - 75 Hz |
Horizontal Refresh Rate | 30 - 90 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Photo Effect, Frame Rate Control (FRC), game mode, Cinema Mode, Mega Dynamic Contrast Ratio, CustomColor Mode, Vivid Color, FPS Mode, Crosshair Display, Flicker Safe, Reader Mode, SIX Axis Control, RTS Mode, MaxxAudio, Smart Energy Saving technology, Color Calibrated, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, split screen 2.0, My Display Preset, Color Weakness Mode, Original ratio, One Click Stand, Super Resolution+, 99% sRGB colour gamut |
Dimensions (WxDxH) | 82.56 cm x 23 cm x 46.07 cm - with stand |
Weight | 7.6 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
Height Adjustment | 110 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), key lock |
Included Accessories | Cable holder |
Cables Included | 1 x HDMI cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption SDR (On mode) | 37.8 kWh/1000h |
Power Consumption HDR (On mode) | 35.6 kWh/1000h |
Power Consumption (Typical) | 42 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 82.56 cm - depth: 23 cm - height: 46.07 cm - weight: 7.6 kg , Without stand - width: 82.56 cm - depth: 5.12 cm - height: 36.98 cm - weight: 5.9 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 94 cm |
Shipping Depth | 49 cm |
Shipping Height | 24 cm |
Shipping Weight | 11.2 kg |
