The W319UST, is perfect for businesses, schools and colleges. It is bright (3300 lm) and a throw ratio of 0.27:1 means that it can project a 100? image from less than 0.5 m away. And having the projector installed so close to the screen avoids any shadows being cast across the screen from the presenter. It provides a complete package for engaging learning with many advanced features, including two HDMI inputs, powered USB port, powerful 16 W built-in speaker, improved lamp life, compact chassis and a completely ultimate mounting system for a fast and simple set up.
Product Description | Optoma W319UST - DLP projector - ultra short-throw - 3D | Device Type | DLP projector - 720p | 3D Capable | Yes (3D glasses sold separately) | Built-in Devices | Speaker | Microdisplay | DarkChip 3 | Brightness | 3300 ANSI lumens | Contrast Ratio | 18000:1 | Resolution | WXGA (1280 x 800) | Native Aspect Ratio | 16:10 | Colour Support | 1.07 billion colours | Lens | Ultra short-throw fixed lens | Bulb type | 190 Watt | Bulb life cycle | Up to 4500 hour(s) - normal mode , Up to 7000 hour(s) - economic mode | Video Input | RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC) | Video Modes | 480p, 720p, 1080i, 480i, 576i, 576p | Speakers | Speaker(s) - integrated | Power | AC 120/230 V (50/60 Hz) | Power Consumption Operational | 235 Watt | Dimensions (WxDxH) | 38.5 cm x 31 cm x 12 cm |
General | |
Networking | Ethernet |
Projector | |
Image Size | 216 cm - 292 cm |
Projection Distance | 0.49 m - 0.66 m |
Throw Ratio | 0.27:1 |
Uniformity | 85 % |
Resolution | WXGA - WXGA (1280 x 800) |
Max Sync Rate (V x H) | 85 Hz x 91.1 kHz |
OSD Languages | Danish, Hungarian, Czech, Thai, Slovak, Chinese (traditional), Chinese (simplified), Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean |
Features | BrilliantColor, 16:9 aspect ratio support, DarkChip3 single-chip DLP technology, PJlink, Crestron RoomView, 4:3 aspect ratio support, AMX Device Discovery, Auto Power Off, Eco+ technology |
Lens | |
Type | Ultra short-throw fixed lens |
Lens Aperture | F/2.4 |
Keystone Correction Direction | Vertical |
Vertical Keystone Correction | -20 / +20 |
Video Input | |
TV System | PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC |
Analogue video Signal | RGB, composite video |
Video Interfaces | VGA, HDMI, composite video |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 16 Watt |
Speakers | 1 x mixed channel |
Expansion / Connectivity | |
Interfaces | 2 x HDMI - 19 pin HDMI Type A , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x microphone - mini-phone 3.5 mm , 1 x USB , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB (power only) - 4 pin USB Type A (power only) , 1 x 3D Sync out |
Miscellaneous | |
Included Accessories | Wireless remote control |
Cables Included | 1 x VGA cable |
Security Features | Security lock slot (cable lock sold separately), password protection, security bar |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS |
Power | |
Power Source | AC |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Width | 38.5 cm |
Depth | 31 cm |
Height | 12 cm |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 0 - 85% |
Sound Emission (Economic Mode) | 26 dB |
