Optoma W320USTiP Interactive Ultra Short Throw Projector
Key features
  • TouchBeam finger touch interactive
  • Bright projection
  • WXGA resolution
  • HDMI input
  • Powerful audio
  • Crestron RoomView technology
  • RJ-45 control and monitoring
Product codes
The W320USTi is perfect for businesses, schools and colleges. It is bright and uses an advanced TouchBeam finger-touch interactive technology, enabling several people to work simultaneously on the screen without using a pen. The optimal throw ratio allows it to project an image from less than 0.5 m away. And having the projector installed so close to the screen avoids any shadows being cast across the screen from the presenter (s). The projector provides a complete package for engaging learning with many convenient features, including two HDMI inputs, powered USB port, powerful built-in speaker, improved lamp life, compact chassis and a convenient mounting system for a fast and simple setup.
Product Description Optoma W320USTiP - DLP projector - ultra short-throw - 3D
Device Type DLP projector - 720p
3D Capable Yes (3D glasses sold separately)
Built-in Devices Speaker
Microdisplay DarkChip 3
Brightness 4000 ANSI lumens
Contrast Ratio 20000:1
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Lens Ultra short-throw fixed lens
Bulb type 260 Watt
Bulb life cycle Up to 3000 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
Video Input RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes 480p, 720p, 1080i, 480i, 576i, 576p
Speakers Speaker(s) - integrated
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 310 Watt
Dimensions (WxDxH) 38.5 cm x 31 cm x 9.9 cm
Weight 4.85 kg
Pricing Type Public Sector only
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Optoma W320USTiP Inter...
