Enjoy vivid LED pictures with this attractive, glossy design display. Equipped with stereo speakers, it's a great choice!
SmartContrast for rich black details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
LED technology for vivid colours
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content, which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of the LCD backlight, resulting in a super high contrast ratio. It also gives superior colour reproduction thanks to consistent brightness across the screen.
Powerful sound with 2 x 2 watts RMS speakers
Now you can enjoy all your multimedia and social applications with stereo sound. These built-in speakers not only sound great, but also help you to get rid of external wire clutter and save valuable desktop space.
Mercury Free eco-friendly display
Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
Product Description | Philips V-line 200V4LAB2 - LED monitor - 20" | Device Type | LED-backlit LCD monitor - 20" | Energy Class | Class E | Power Consumption (On mode) | 13 W | Aspect Ratio | 16:9 | Native Resolution | 1600 x 900 at 60 Hz | Pixel Pitch | 0.2698 mm | Brightness | 200 cd/m² | Contrast Ratio | 600:1 / 10000000:1 (dynamic) | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Textured black, glossy black | Dimensions (WxDxH) - with stand | 47.9 cm x 20.1 cm x 36.9 cm | Weight | 2.72 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, UL, TUV, BSMI, cUL, SEMKO, DDC/CI, RoHS, Lead-Free, WEEE, CECP, EAC, ISO9241-307 | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 20" |
Viewable Size | 19.5" |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 90 |
Vertical Viewing Angle | 65 |
Backlight Technology | WLED |
Controls & Adjustments | Volume, brightness |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features | Sync on Green, sRGB colour management, SmartContrast, Mercury free |
Dimensions (WxDxH) | 47.9 cm x 20.1 cm x 36.9 cm - with stand |
Weight | 2.72 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) , Audio line-in |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
MTBF | 30,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 13 kWh/1000h |
Power Consumption (Typical) | 19 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
OS Required | Apple MacOS X, Microsoft Windows XP / 7 / 8 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 47.9 cm - depth: 20.1 cm - height: 36.9 cm - weight: 2.72 kg , Without stand - width: 47.9 cm - depth: 4.8 cm - height: 29.9 cm - weight: 2.39 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
