16:9 Full HD display for crisp, detailed images
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
SmartContrast for rich black details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
HDMI-ready for Full HD entertainment
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
LED technology for vivid colours
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content, which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of the LCD backlight, resulting in a super high contrast ratio. It also gives superior colour reproduction thanks to consistent brightness across the screen.
Easy display performance tuning with SmartControl Lite
SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc with the mouse.
Mercury Free eco-friendly display
Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
Product Description | Philips V-line 243V5LHSB - LED monitor - Full HD (1080p) - 23.6" | Device Type | LED-backlit LCD monitor - 23.6" | Energy Class | Class F | Energy Consumption per Year | 40 kWh | Power Consumption (On mode) | 19.5 W | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.272 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 10000000:1 (dynamic) | Response Time | 5 ms (typical), 1 ms (grey-to-grey with overdrive) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Textured black, black hairline | Dimensions (WxDxH) - with stand | 55.1 cm x 22 cm x 42 cm | Weight | 3.66 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, cETLus | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.6" |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean, Iberian Portuguese |
Features | Sync on Green, sRGB colour management, SmartContrast, 4:3 in Wide, Mercury free |
Dimensions (WxDxH) | 55.1 cm x 22 cm x 42 cm - with stand |
Weight | 3.66 kg |
Connectivity | |
Interfaces | VGA , HDMI (HDCP) , DVI-D (HDCP) |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
MTBF | 30,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 20 kWh/1000h |
Power Consumption (Typical) | 18.59 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.3 Watt |
On / Off Switch | No |
Software / System Requirements | |
Included Software | Philips SmartControl Lite |
OS Required | Apple MacOS X, Microsoft Windows 7, Windows 8 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 55.1 cm - depth: 22 cm - height: 42 cm - weight: 3.66 kg , Without stand - width: 55.1 cm - depth: 5.2 cm - height: 34.4 cm - weight: 3.22 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
