Enjoy vivid LED pictures with this attractive, glossy design display. Equipped with HDMI, it's a great choice!
Product Description | Philips V-line 246V5LDSB - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class E | Energy Consumption per Year | 29 kWh | Power Consumption (On mode) | 18 W | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.277 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 10000000:1 (dynamic) | Response Time | 1 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Textured black, glossy black | Dimensions (WxDxH) - with stand | 56.5 cm x 23.8 cm x 43.5 cm | Weight | 4.65 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, TUV, BSMI, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features | Sync on Green, sRGB colour management, HDCP, SmartResponse, SmartContrast, Flicker Free technology, Mercury free |
Dimensions (WxDxH) | 56.5 cm x 23.8 cm x 43.5 cm - with stand |
Weight | 4.65 kg |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) , HDMI (HDCP) |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable |
MTBF | 30,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 18 kWh/1000h |
Power Consumption (Typical) | 15.66 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
On / Off Switch | No |
Software / System Requirements | |
OS Required | Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 56.5 cm - depth: 23.8 cm - height: 43.5 cm - weight: 4.65 kg , Without stand - width: 56.5 cm - depth: 6.3 cm - height: 35.4 cm - weight: 4.22 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
