The expansive 43" class Ultra HD professional Philips display gives you the room to spread out, see the big picture and all the details in 4K Ultra High Definition (four times the resolution of Full HD).
Product Description | Philips Brilliance BDM4350UC - LED monitor - 4K - 43" | Device Type | LED-backlit LCD monitor - 43" | Energy Class | Class B | Energy Consumption per Year | 146 kWh | Power Consumption (On mode) | 100 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.2451 mm | Brightness | 300 cd/m² | Contrast Ratio | 1200:1 / 50000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Input Connectors | 2xHDMI(MHL), 2xDisplayPort, VGA | Screen Coating | UltraClear | Voltage | AC 120/230 V (50/60 Hz) | Colour | Glossy black with textured back cover, textured silver stand | Dimensions (WxDxH) - with stand | 96.8 cm x 25.9 cm x 63 cm | Weight | 9.72 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, TUV, VCCI, BSMI, ICES-003, SASO, SEMKO, CB, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, KCC, WEEE, PSE Mark, J-MOSS, E-Standby, KUCAS, CECP, EPA, EAC, cETLus, China RoHS, RCM |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 43" |
Viewable Size | 42.51" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 23 - 80 Hz |
Horizontal Refresh Rate | 30 - 160 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features | Picture in picture, Sync on Green, sRGB colour management, MultiView, SmartImage, SmartConnect, Flicker Free technology, BFR/PVC-free, slim bezel design, Mercury free, PBP, SmartUniformity, USB 3.0 Fast Charge |
Dimensions (WxDxH) | 96.8 cm x 25.9 cm x 63 cm - with stand |
Weight | 9.72 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 7 Watt |
Connectivity | |
Interfaces | VGA , 2 x MHL / HDMI , 2 x DisplayPort , 4 x USB 3.0 , Audio line-in , Headphones |
Mechanical | |
VESA Mounting Interface | 200 x 200 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
MTBF | 70,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
Included Software | Philips SmartControl |
OS Required | Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 96.8 cm - depth: 25.9 cm - height: 63 cm - weight: 9.72 kg , Without stand - width: 96.8 cm - depth: 8.2 cm - height: 56.2 cm - weight: 9.4 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
