We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Experience a new level of entertainment immersion with the new Momentum 4K HDR display with Ambiglow lighting. An expansive 4K UHD display with DisplayHDR 1000 delivers ultra-crisp and vibrant image quality that will get you in the moment.
Product Description | Philips Momentum 436M6VBPAB - LED monitor - 4K - 43" - HDR | Device Type | LED-backlit LCD monitor - 43" | Energy Class | Class G | Energy Consumption per Year | 201 kWh | Power Consumption (On mode) | 67 W | Features | USB 3.0 hub | Panel Type | MVA | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.245 mm | Brightness | 1000 cd/m² | Contrast Ratio | 4000:1 / 50000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Colour Gamut | 97.6% DCI-P3, 100% BT.709, 119% NTSC, 145% sRGB | Input Connectors | HDMI, DisplayPort, Mini DisplayPort, USB-C | Display Position Adjustments | Tilt | Screen Coating | Anti-glare, 3H Hard Coating, low haze | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black gloss textured | Dimensions (WxDxH) - with stand | 97.6 cm x 26.4 cm x 66.1 cm | Weight | 14.71 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | FCC Class B certified, TUV, VCCI, BSMI, ICES-003, SASO, SEMKO, CB, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, KCC, WEEE, PSE Mark, ICES, J-MOSS, E-Standby, KC, KUCAS, EAC, cETLus, China RoHS, RCM, Ukraine |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 43" |
Viewable Size | 42.51" |
Built-in Devices | USB 3.0 hub |
Panel Type | MVA |
Pixel Per Inch | 103.64 |
Vertical Refresh Rate | 23 - 80 Hz |
Horizontal Refresh Rate | 30 - 160 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese |
Features | Picture by picture, Sync on Green, SmartImage, Frame Rate Control (FRC), Ambiglow, Low Blue Light Mode, Flicker Free technology, Mercury free, DTS Sound, Low Input Lag, Quantum Dot Technology, Picture-in-Picture |
Dimensions (WxDxH) | 97.6 cm x 26.4 cm x 66.1 cm - with stand |
Weight | 14.71 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 7 Watt |
Connectivity | |
Interfaces | HDMI , DisplayPort , Mini DisplayPort , USB-C/DisplayPort 1.2 Alt Mode , 2 x USB 3.0 downstream with Power Charging (Type A) , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+10 |
VESA Mounting Interface | 200 x 200 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | USB-C cable , USB to USB-C cable , HDMI cable , DisplayPort cable |
MTBF | 50,000 hour(s) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 67 kWh/1000h |
Power Consumption HDR (On mode) | 160 kWh/1000h |
Power Consumption (Typical) | 162 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 97.6 cm - depth: 26.4 cm - height: 66.1 cm - weight: 14.71 kg , Without stand - width: 97.6 cm - depth: 6.3 cm - height: 57.4 cm - weight: 13.96 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 109 cm |
Shipping Depth | 33.8 cm |
Shipping Height | 76.4 cm |
Shipping Weight | 20.72 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 7.0 |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
