This Philips UltraWide 34" display will amaze you with its Crystal clear 3440 x 1440 images and brilliant colours. Its fascinating UltraWide display with height adjustability gives you a panoramic view of the world.
Product Description | Philips Brilliance X-line 349X7FJEW - LED monitor - curved - 34" | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class C | Energy Consumption per Year | 114 kWh | Power Consumption (On mode) | 78 W | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync | Features | USB 3.0 hub | Aspect Ratio | 21:9 | Native Resolution | 3440 x 1440 at 60 Hz | Pixel Pitch | 0.232 mm | Brightness | 300 cd/m² | Contrast Ratio | 3000:1 / 50000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 99.5% sRGB | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Height, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | White, glossy, silver chrome | Dimensions (WxDxH) - with stand | 81 cm x 29.2 cm x 44.4 cm | Weight | 8.21 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, TUV, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, RCM, CU-EAC |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 34" |
Curved Screen | Yes (1800R) |
Built-in Devices | USB 3.0 hub |
Vertical Refresh Rate | 40 - 100 Hz |
Horizontal Refresh Rate | 58 - 148 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features | Picture in picture, picture by picture, Sync on Green, sRGB colour management, SmartImage, SmartImage Game, Flicker Free technology, Mercury free, Wide Viewing Angle |
Dimensions (WxDxH) | 81 cm x 29.2 cm x 44.4 cm - with stand |
Weight | 8.21 kg |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , Audio line-in/out , Headphones , 4 x USB 3.0 downstream , USB 3.0 upstream |
Mechanical | |
Tilt Angle | -5/+20 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable , 1 x audio cable |
MTBF | 50,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 69.95 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
On / Off Switch | No |
Software / System Requirements | |
OS Required | Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 81 cm - depth: 29.2 cm - height: 44.4 cm - weight: 8.21 kg , Without stand - width: 810 cm - depth: 9.8 cm - height: 36.9 cm - weight: 6.43 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
