240Hz RapidCurve, 1ms response time, and G-Sync compatibility raise you to the top of your game
QLED, HDR600, and WQHD 2560 x 1440p resolution come together for spectacular colours with total depth and detail
G-Sync compatibility keeps the GPU and panel synced up to eliminate choppiness, screen-lag, and image tears. Fast-action and complex game scenes are stable and stutter-free with AMD FreeSync Premium Pro for your competitive edge
Product Description | Samsung Odyssey G7 C27G75TQSR - G75T Series - QLED monitor - curved - 27" - HDR | Device Type | QLED monitor - 27" | Energy Class | Class G | Energy Consumption per Year | 47 kWh | Power Consumption (On mode) | 32 W | Curved Screen | Yes | Adaptive-Sync Technology | NVIDIA G-SYNC, AMD FreeSync Premium Pro | Features | USB 3.0 hub | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | WQHD 2560 x 1440 at 240 Hz | Brightness | 600 cd/m² | Contrast Ratio | 2500:1 | HDR Capable | DisplayHDR 600 | Response Time | 1 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Colour Gamut | 125% sRGB, 95% DCI-P3 | Input Connectors | HDMI, 2xDisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V | Colour | Black | Dimensions (WxDxH) - with stand | 61.46 cm x 30.59 cm x 57.6 cm | Weight | 7.2 kg |
General | |
Display Type | QLED monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 27" |
Viewable Size | 26.9" |
Curved Screen | Yes (1000R) |
Built-in Devices | USB 3.0 hub |
Panel Type | VA |
HDR Certification | DisplayHDR 600 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | HighBrightness, picture by picture, Cinema Mode, Black eQualizer, CustomColor Mode, FPS Mode, Mega Infinity Dynamic Contrast Ratio, Flicker Free technology, RTS Mode, USB Super-charging, Eye Saver Mode, Factory Tunning, Factory Calibration Report, Smart Eco Saving, Off Timer Plus, Low Input Lag, Quantum Dot Technology, Super Arena Gaming UX, Screen Size Optimizer, Refresh Rate Optimizer, RPG Mode, AOS Mode, sRGB Mode, Picture-in-Picture, Dynamic Contrast Mode, Core lighting design |
Colour | Black |
Dimensions (WxDxH) | 61.46 cm x 30.59 cm x 57.6 cm - with stand |
Weight | 7.2 kg |
Connectivity | |
Interfaces | 2 x DisplayPort 1.4 , HDMI , Headphones , 2 x USB 3.0 |
Mechanical | |
Tilt Angle | -9/+13 |
Swivel Angle | 30 |
Rotation Angle | -2/+92 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x DisplayPort cable , 1 x SuperSpeed USB cable |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption SDR (On mode) | 32 kWh/1000h |
Power Consumption HDR (On mode) | 66 kWh/1000h |
Power Consumption (Typical) | 100 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.46 cm - depth: 30.59 cm - height: 57.6 cm - weight: 7.2 kg , Without stand - width: 61.46 cm - depth: 17.1 cm - height: 38.28 cm - weight: 5.5 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 71.5 cm |
Shipping Depth | 50.7 cm |
Shipping Height | 26.3 cm |
Shipping Weight | 10.5 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
