This monitor delivers more screen space and amazingly life-like images. That means you can view documents and webpages with less scrolling, work more comfortably with multiple windows and toolbars, and enjoy photos, videos and games in stunning quality.
Product Description | Samsung U32J590UQU - LED monitor - 4K - 32" | Device Type | LED-backlit LCD monitor - 32" | Energy Class | Class G | Energy Consumption per Year | 69 kWh | Power Consumption (On mode) | 47 W | Adaptive-Sync Technology | AMD FreeSync | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Brightness | 270 cd/m² | Contrast Ratio | 3000:1 | Response Time | 4 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Tilt | Voltage | AC 120/230 V | Colour | Dark grey/blue | Dimensions (WxDxH) - with stand | 72.95 cm x 25.05 cm x 53.45 cm | Weight | 6.3 kg | Compliant Standards | DisplayPort 1.2 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 32" |
Viewable Size | 31.5" |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Picture by picture, game mode, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Mega DFC, Picture-in-Picture |
Dimensions (WxDxH) | 72.95 cm x 25.05 cm x 53.45 cm - with stand |
Weight | 6.3 kg |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , Headphones |
Mechanical | |
Tilt Angle | -2/+15 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | HDMI cable |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption SDR (On mode) | 47 kWh/1000h |
Power Consumption (Typical) | 59 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
Included Software | Easy Setting Box |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 72.95 cm - depth: 25.05 cm - height: 53.45 cm - weight: 6.3 kg , Without stand - width: 72.95 cm - depth: 5.64 cm - height: 42.78 cm - weight: 5.5 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 79.2 cm |
Shipping Depth | 49.1 cm |
Shipping Height | 15.7 cm |
Shipping Weight | 8.4 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
