Samsung's advanced display delivers richer, more vivid colors bringing movies, sports broadcasts live-streamed gaming and more to life. Multi-coated semiconductor particles ensure long-lasting image quality while Samsung's unique cadmium-free technology is harmless to the environment.
Product Description | Samsung C32H711QEU - CH71 Series - QLED monitor - curved - 32" | Device Type | QLED monitor - 32" | Energy Class | Class B | Energy Consumption per Year | 80 kWh | Power Consumption (On mode) | 55 W | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | WQHD 2560 x 1440 at 60 Hz | Pixel Pitch | 0.2767 mm | Brightness | 300 cd/m² | Contrast Ratio | 3000:1 | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, Mini DisplayPort | Display Position Adjustments | Tilt | Voltage | AC 120/230 V | Colour | White | Dimensions (WxDxH) - with stand | 71.25 cm x 27.63 cm x 51.9 cm | Weight | 6.8 kg | Compliant Standards | Plug and Play, DDC-2B, EMI, ISO 9241-307 Class 2 |
General | |
Display Type | QLED monitor / TFT active matrix |
Diagonal Size | 32" |
Viewable Size | 31.5" |
Curved Screen | Yes (1800R) |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | MagicBright, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Flicker Free technology, Eye Saver Mode, Quantum Dot Technology |
Colour | White |
Dimensions (WxDxH) | 71.25 cm x 27.63 cm x 51.9 cm - with stand |
Weight | 6.8 kg |
Connectivity | |
Interfaces | HDMI , Mini DisplayPort |
Mechanical | |
Tilt Angle | -2/+15 |
Miscellaneous | |
Features | 360° rotation |
Cables Included | 1 x HDMI cable |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption (Typical) | 59 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 71.25 cm - depth: 27.63 cm - height: 51.9 cm - weight: 6.8 kg , Without stand - width: 71.25 cm - depth: 6.28 cm - height: 42.07 cm - weight: 5.3 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
