Clear picture quality with fast response time
Easy on the eyes for a more comfortable viewing experience
Save energy with energy-efficient features
Eco-friendly materials with Intertek Green Leaf certification
Optional mountable USB soundbar
A professional ergonomic monitor for truly professional needs
Product Description | Samsung S22E200B - SE200 Series - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class G | Power Consumption (On mode) | 24 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.24825 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms | Colour Support | 16.7 million colours | Colour Gamut | 72% (CIE 1976) | Input Connectors | DVI, VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V | Colour | Black | Dimensions (WxDxH) - with stand | 50.43 cm x 17 cm x 38.54 cm | Weight | 3.37 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | C-Tick, EN55022, SASO, EN55024, FCC Part 15 B, CCC, PSB, AS/NZS 3548, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, GB 4943-2011, GB 17625.1-2012 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Panel Type | TN |
Vertical Refresh Rate | 60 Hz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | MagicBright, power off timer, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving |
Colour | Black |
Dimensions (WxDxH) | 50.43 cm x 17 cm x 38.54 cm - with stand |
Weight | 3.37 kg |
Connectivity | |
Interfaces | VGA , DVI |
Mechanical | |
Tilt Angle | -2/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | PVC free |
Cables Included | 1 x VGA cable - 1.5 m |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption SDR (On mode) | 24 kWh/1000h |
Power Consumption (Typical) | 21 Watt |
Power Consumption Stand by | 0.1 Watt |
Power Consumption Sleep | 0.1 Watt |
Software / System Requirements | |
OS Required | Windows 8.1 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 50.43 cm - depth: 17 cm - height: 38.54 cm - weight: 3.37 kg , Without stand - width: 50.43 cm - depth: 7.75 cm - height: 30.19 cm - weight: 3.08 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
